2trees
Nov 22, 2013Aspirant
ReadyNAS Duo V1 Capacity max.
I note from the original HDD compatibility listing, that my current unit will accept 1.5TB units. As the model reccomended is no longer available could you please advise current approved drives, great...
Dec 04, 2013Guru - Experienced User
to reboot: From frontview, select "system", then "shutdown"
Check "shutdown and reboot device", then click apply at the bottom right.
Also, what are you seeing on the volume page (particularly what does Frontview say is "allocated" for each drive)?
