2trees
Nov 22, 2013Aspirant
ReadyNAS Duo V1 Capacity max.
I note from the original HDD compatibility listing, that my current unit will accept 1.5TB units. As the model reccomended is no longer available could you please advise current approved drives, great...
Dec 05, 2013Guru - Experienced User
Disk Spindown on the NAS, not the PC. With frontview select system, then power.
I suggest that at some point you should "walk through" the frontview menus to help you understand the various settings and features better.
