Marova's avatar
Marova
ReadyNas Duo v1 changing hard drive
SOLVED: I didn't hotinsert the new disk, feeling kind of stupid but can't delete this discussion...
Ok, so a couple of month's back I started having trouble with one of the hard drives (drive 1) in my ReadyNAS Duo. I thought it fixed after some help here but a couple of weeks later the problem was back. So I bought a new hard drive to replace the old one but the NAS doesn't synchronize and RAIDar still thinks it's the faulty drive that's installed. How do I get my ReadyNAS to synchronize with the new drive?
OS: Windows 10
Device: ReadyNAS Duo RND2000 v1
Old (Channel 1) Drive: Hitachi HDS721010CLA332
New (Channel 1) Drive: WDC WD10EZEX
Channel 2 Drive: Seagate ST1000DM003
  • Sometimes the linux drivers will mark the interface as down when the drive fails (depending on exactly how it failed).
    If you have access to the data, you should do a backup (since it is at risk).
    After that, try powering down, removing the drive, and rebooting the NAS with the slot empty.  Then hot-insert the disk (with the NAS running).
1 Reply
  • StephenB's avatar
ProSupport for Business
