uxphil
Mar 30, 2016Aspirant
ReadyNas Duo v1 disk upgrade - space expansion not shown
Hi, One of my disks in my ancient, but trusty ReadyNas Duo v1 (Firmware: RAIDiator 4.1.14 [1.00a043] ) had died and I decided to upgrade the disks to the following: WD 2TB SATA lll Hard Drive...
uxphil
Thanks fo the tip, but it wasn't turned on to start with.
That's in System > Power, right?
Or is there another option?
uxphil
Also, here are the performance options that I have:
Enable disk write cache. = ON
Disable full data journaling. = ON
Disable journaling. = OFF
Enable fast CIFS writes. = ON
Enable fast USB disk writes. = OFF
Power options:
Enable disk spin-down = OFF
- JennCMar 30, 2016NETGEAR Employee Retired
Hello uxphil,
Does the FrontView > Volumes have Volume Maintenance option? Sorry I'm not that sure if Duo v1 has this option, the Intel-based ones have.
If none, since you have backup of the data, maybe you can try resetting to factory?
- StephenBMar 30, 2016Guru - Experienced User
Unfortunately it doesn't.
- mdgm-ntgrMar 31, 2016NETGEAR Employee Retired
Those settings look fine. Not sure why the expansion didn't take place. I agree with JennC that since you have a backup, resetting the NAS to factory defaults then restoring from backup could be a good way to go.
An advantage of this also is that if you last did a factory default on firmware older than 4.1.7 you wouldn't currently have 4k sector partition alignment. Whereas if you do a factory default on 4.1.7 or later you will get that.
