SivertP
Jan 10, 2018Aspirant
Readynas duo V1 no connection with Technicolor tg799vac
I use Windows 10, 64 bit latest update, My ReadyNAS will not connect to Telia Fiber Gateway Technicolor TG799VAC Extreme via NW contact, if I use my older router Huawei E5172 it connects without prob...
- Jan 16, 2018
OK and many thanks for your very quick response, it seems wise to follow your advice !
SivertP
Hi I thougt I already answered, but can't see so I try again:
"NW contact" I just mean the cable connection between Technicolor and ReadyNas
LED close to "cable entry" shows activity when connected to Huawei but not to Technicolor
NAS conigured to use DHCP
Huawei using 192.168.1.1 - 192.168.154, Technicolor I can't see, probabl the sam since connected devices hav adree within that range
I attach main screen for Technicolor
Jan 10, 2018Guru - Experienced User
Is the LED on back of the NAS side? Or do you only mean the LED on the router?
Do you have an ethernet switch you can put between the NAS and the Technicolor?
- SivertPJan 10, 2018Aspirant
LED is on the back of NAS. I have no switch, do you thik that could solve the problem ?
