SivertP
Jan 10, 2018Aspirant
Readynas duo V1 no connection with Technicolor tg799vac
I use Windows 10, 64 bit latest update, My ReadyNAS will not connect to Telia Fiber Gateway Technicolor TG799VAC Extreme via NW contact, if I use my older router Huawei E5172 it connects without prob...
- Jan 16, 2018
OK and many thanks for your very quick response, it seems wise to follow your advice !
SivertP
Jan 16, 2018Aspirant
No connection with NAS in the ethernet port of a PC. Huawei 5172 seems to be the only way so far. Could it be any settings in Windows 10 that crucial for the connectio to function ?
Jan 16, 2018Guru - Experienced User
The LED link light is physical-layer (e.g, electrical), so it is not related to Windows 10. Plus the issue is happening with three different devices - a switch, a router, and the PC.
While I don't know why the Huawei is working, I am thinking that it could also fail at any time.
So I suggest connecting up the Huawei again, and backing up the data on the NAS. Then I recommend replacing it (a ReadyNAS RN 212 would be the currently shipping equivalent).
That also will boost your performance by 4-5x, and give you SMBv3 support. The SMBv1 protocol that your Duo is using is no longer considered secure, and Microsoft is taking steps to remove it. Though that's not your current problem, it is becoming an issue.
- SivertPJan 16, 2018Aspirant
