clblackman
Nov 21, 2015Aspirant
ReadyNAS Duo v1 OS Reinstall questions
From my previous post: I have purchased another seagate 2tb drive and was able to install the os the drive from disc 1 slot. So I have eliminated that the controller for the Duo has gone bad. I ha...
BrianL2
Jan 03, 2016NETGEAR Employee Retired
Hi clblackman,
Does the device still show up in RAIDar? Could you try to do a ping via cmd? Also, check if you can access https://192.168.1.61/admin/.
Kind regards,
BrianL
NETGEAR Community Team
mdgm-ntgr
An OS Re-install won't necessarily fix corrupt root. It does depend what caused it.
If you have corrupt root due to a full 2GB root volume for example, then doing an OS Re-install may actually make your problems worse.
Do you have a backup?
- clblackmanJan 16, 2016Aspirant
I do not have a backup of my raid.
What are my options if the device is full?
- StephenBJan 16, 2016Guru - Experienced User
It'd be helpful if you answered Brian's questions:
