walkz187
Jul 10, 2017Aspirant
Readynas Duo v1 Slow Write speeds
Hi All Hoping someone with more knowledge than i could help with my slow write speed i am getting on my ReadyNas duo v1. if setup as a raid 1i get about 5MB/s if setup as raid 0 i get 7MB/s. eith...
walkz187
Jul 11, 2017Aspirant
Thanks JennC for your reply.
I tried connecting directly as you suggested and received the same slow writing speed, 7MB/s. Since i placed this help request up i have purchased a second hand readynas RND4000v3. i have tried the same drives in this other NAS and sames speeds as well. I then took out the drives and did a speed test directly from my Mac via a USB 2 adapter and received around 38MB/s write and 44MB/s read on both of my 2 TB drives. so unlikleky a drive issue. so the only conclusion i can come up with is both readyNAS systems are the kinks in the chain, OSX is via the readynas or my settings.
FYI i also tried my Mac book air via WIFI > R6300 roucter > readynas. speeds are also asymetrical around 4.5MB/s write and 20MB/s read. i also have tried different optons on Imac ethernet. no firewall.
its also worth noting error logs on the Ethernet, this was reset and took about 1 hours to accumulate:
Auto Negotiations 3
Bad packets 0
Disconnect 0
False Carrier 3
Idle Errors 510
Link Failures 0
Received Errors 21451
Symbol Errors 1
VLAN tags 0
TCP Retransmits 20
Unrecovered TCP Retransmits 17
Jul 11, 2017Guru - Experienced User
20K Received errors over an hour looks pretty high to me.
Did you try a different ethernet cable?
