walkz187
Jul 10, 2017Aspirant
Readynas Duo v1 Slow Write speeds
Hi All Hoping someone with more knowledge than i could help with my slow write speed i am getting on my ReadyNas duo v1. if setup as a raid 1i get about 5MB/s if setup as raid 0 i get 7MB/s. eith...
walkz187
Jul 11, 2017Aspirant
Thanks for you reply StephenB
Yes I have tried multiple cables - and speeds were the same.
For clarification it may of been between 1-2 hours. But no longer. all direct IMac connected readynas.
Are these readynas designed to get anymore speed than 7MB/s writing. Feel like I have tried everything, every setting combination
- StephenBJul 11, 2017Guru - Experienced User
The more serious errors you are showing are layer-1/layer-2 (physical/ethernet)..
If you are seeing the receive errors in all your testing (with multiple devices and cables), then the ethernet port on your duo is failing.
Unfortunately that can't be repaired.
