walkz187
Jul 10, 2017Aspirant
Readynas Duo v1 Slow Write speeds
Hi All Hoping someone with more knowledge than i could help with my slow write speed i am getting on my ReadyNas duo v1. if setup as a raid 1i get about 5MB/s if setup as raid 0 i get 7MB/s. eith...
walkz187
Jul 11, 2017Aspirant
I don't think this would be it. Because I just got another second hand readynas rnd4000 and the same issue is occurring. Maybe I'll go buy a brand new high end cable and see.
Jul 11, 2017Guru - Experienced User
If you have a windows PC, I'd also suggest testing the NAS with NasTester( http://www.808.dk/?code-csharp-nas-performance )
Overall, you should be seeing write speeds in the 18-25 megabyte range for large file transfers. At least that what I've always seen on my duo and NV+.
If you are looking for a serious performance boost, the best option is to upgrade to a modern OS-6 NAS. An RN21x or better is limited by your gigabit ethernet speed (100+ megabytes per second for large file transfers).
