walkz187
Jul 10, 2017Aspirant
Readynas Duo v1 Slow Write speeds
Hi All Hoping someone with more knowledge than i could help with my slow write speed i am getting on my ReadyNas duo v1. if setup as a raid 1i get about 5MB/s if setup as raid 0 i get 7MB/s. eith...
walkz187
Jul 11, 2017Aspirant
I would be more than happy with 18MB. Have no need for anymore. I got rid of my PCs last year and work Laptop is well locked up with the need for admin privileges to do anything. Do you think it could be an OSX issue? Do you know what speeds Mac normally get when connected to a readynas. Maybe 7MB is ok. I got 8.5mb when I changed it to jumbo packets.
Might need to try run windows via virtual machine to do you test.
Jul 11, 2017Guru - Experienced User
Kind of hard to say what it is when you only have one test device. The receive errors are happening on the ethernet layer, but it's not easy to tell what impact those are having on speed.
I think there is a setting in frontview related to OSX optimization, but I'm not sure what it does and if it helps with current OSX.
What firmware are you running?
