orlik09
Nov 23, 2020Aspirant
ReadyNAS Duo v1 UPS USB
Good afternoon. I read on the forums that Synology works with the IPPON basic 650 UPS over a usb cable. Turns off when the battery is low and even turns on after power is applied. I bought one for Re...
Nov 23, 2020Guru - Experienced User
orlik09 wrote:
Can I configure my NAS to work with UPS over USB?
There's no easy way to manually configure the UPS behavior. The Duo is very old (went out of production in 2011, and the last software update was 2017). Likely there was a change to the network ups tools (NUTS) software that addressed the interoperability problem, but the NAS never got it.
Are you running the final firmware (4.1.16)?
