disney_cjd
Sep 17, 2012Tutor
ReadyNAS Duo v1 Win 7 user accounts on NAS help
Hi All I have been using my ReadyNAS for a couple of years and have all my user files on there like My Documents, My Music etc, Desktop files. I am running Windows 7. However I have just got a ne...
Sep 17, 2012Guru - Experienced User
Here's a procedure that should do what you want (using the Music library as an example).
1. Create a base folder on your hard drive for shares you want in a library i.e. c:\share
2. Create another folder in the above share. i.e. c:\share\music
3. Link an existing library to this folder. i.e Right-click on the Music library, select properties and choose "include a folder" Enter c:\share\music
4. Delete the folder i.e. c:\share\music
5. Use mklink in an elevated command prompt to make a symbolic link in c:\share that matches the original folder name. I.e. right-click on CMD and run it as administrator. Enter mklink /d c:\share\music \\NASNAME\music on the command line
- Apr 16, 2020Retired_Member
