disney_cjd
Sep 17, 2012Tutor
ReadyNAS Duo v1 Win 7 user accounts on NAS help
Hi All I have been using my ReadyNAS for a couple of years and have all my user files on there like My Documents, My Music etc, Desktop files. I am running Windows 7. However I have just got a ne...
Sep 17, 2012Guru - Experienced User
I use Crashplan, but that is not an option for a duo v1 (since the v1 doesn't support Java).
There are some other sites that offer inexpensive unlimited storage with FTP support. justhost.com is one (though technically using it for backup is not really in the terms of service). http://www.onlinestoragesolution.com is another. I haven't used them. I don't think you should depend on any of these inexpensive cloud storage providers for your primary backup, though I think they do make sense for secondary backup/disaster recovery (if you have a fast enough internet uplink).
- Apr 16, 2020Retired_Member
