Knorske
Jan 14, 2016Aspirant
ReadyNAS duo v1
I have been using my ReadyNAS duo V1 (2150) for quite some time. Suddenly, it quit communicating, and has "disappeared" from my network. The blue "on" button light is on, but it dims, occasionally ...
- Jan 16, 2016
Knorske wrote:
I am almost afraid to ask, but .... I have a second ReadyNAS duo, and it is V2 (versus the V1 which is "in trouble"). Would I encounter the same incompatibility trying to load my V1 disks into the V2 as you indicate I would have trying to use a "new" ReadNAS?
Yes, Your V2 uses an arm processor, so you can't migrate the V1 drives to it.
Knorske wrote:
I know the "use the linux reader" sounds like the proverbial piece of cake, but I am dealing with ALL my data files!! (Yikes! and Good Golly, Miss Molly!!)
Could you please "point" me to a source which will reveal which of the "older" ReadyNAS units are compatible with the disks in my 2150 v1? Is there some "clue" in the model number, or ...?
A duo 2150 shipped with a 500GB drive, so there really isn't a lot of data to copy. Even if you upgraded the disk later, it would only have 2 TB max. Truth is, linux reader is the easiest (and I think safest) next step.
The compatible desktop NAS are duo v1, nv, or nv+ v1. You can use this guide to distinguish v1 from v2: http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
Jan 15, 2016Guru - Experienced User
If you want to extract the data, you could try using linux reader ( http://www.diskinternals.com/linux-reader/ ) on the first disk while you have it connected to the PC.
Knorske
Jan 15, 2016Aspirant
Thank you for the responses.
I have tried the off/on (reboot) option, a couple of times, with no result. ALL my data (expect e-mail, probably) are on the ReadyNAS--my thought, the data are safe there, considering the second-disk-auto-backup. Of course, I was not anticipating the entire unit to shut down. The unit does not show on RAIDar.
If we presume the disks are OK, and the failure is the unit, itself, will placing the disks in a new unit give me access to the disks' data? Netgear no longer sells the model I have, so the "newest" unit would be the 102 (for instance).
If I must extract the data, other than from a a Netgear ReadyNAS, must I install (one of the) disks in my PC?
Again, many thanks!
