rozel
Jun 19, 2012Aspirant
ReadyNas Duo v2 - Installation & Setup
Hi all This is my first post and I admit it is a little noobish, so please go gentle :) After extensive research particularly on this forum, coupled with the fact that I own numerous Netgear p...
Jun 20, 2012Guru - Experienced User
I have a pro (and two v1 products) not the v2...
Generally though it is not a good idea to pull the plug on a syncing raid array (unless you really have no choice). With the other platforms, the time estimates are approximate, and often vary as the syncing proceeds. Note that the raw disk transfer speed varies a huge amount over the disk surface (bit density and rotation speed are constant, so you get a lot more bits per second when you are reading the innermost part of the platter).
Anyway, try to let it run to completion. If it doesn't complete after 24 hours, open a support ticket. If it does complete, check the disk health/SMART statistics.
