rozel
Jun 19, 2012Aspirant
ReadyNas Duo v2 - Installation & Setup
Hi all This is my first post and I admit it is a little noobish, so please go gentle :) After extensive research particularly on this forum, coupled with the fact that I own numerous Netgear p...
rozel
Jun 21, 2012Aspirant
I'll be damned if there is a problem with the discs - at the beginning everything booted up fine but part-way through the Syncing, speed was lost. I pulled the plug as I have just done now once more. Recovery should take place which it was (twice) again everything started off nicely but eventually speed was lost .
Please can you answer my questions in red above? otherwise I cannot move forward. I have no spare PC which I am going to dismantle simply to test my discs - it is the ReadyNas which is proving problematic and if it has destroyed my discs, then I will be on the phone to NetGear - I bought the discs and the ReadyNas from 2 different suppliers.
Roz
Roz
