rozel
Jun 19, 2012Aspirant
ReadyNas Duo v2 - Installation & Setup
Hi all This is my first post and I admit it is a little noobish, so please go gentle :) After extensive research particularly on this forum, coupled with the fact that I own numerous Netgear p...
mdgm-ntgr
Jun 21, 2012NETGEAR Employee Retired
Probably about a day or so.
Doesn't need to be connected to PC but it can be.
Disks can and do fail at any time.
Are you able to access the Dashboard? If so, can you download the logs zip file?
If not able to to access the Dashboard you should put the NAS in tech support mode and forward port 23. With your IP address tech support (http://www.readynas.com/support) should be able to investigate whether there's a bad disk.
