rozel
Jun 19, 2012Aspirant
ReadyNas Duo v2 - Installation & Setup
Hi all This is my first post and I admit it is a little noobish, so please go gentle :) After extensive research particularly on this forum, coupled with the fact that I own numerous Netgear p...
rozel
Jun 21, 2012Aspirant
Thank you mdgm - I'm just trying to work this thing out. I have just plugged the ethernet cable back in but now even RAIDar doesn't see it! LED is still blinking away though. I will restart my PC, see what gives then and decide what to do next over a cup of coffee.
If I should go the Factory Reset route, should I start with one disc then add the second afterwards? Or is it best to leave them both in situ? As I said, I want 2 x 3TB volumes, so what RAID version or should I say options should I select?
Thanks again your advice has been much appreciated :)
Roz
Roz
