rozel
Jun 19, 2012Aspirant
ReadyNas Duo v2 - Installation & Setup
Hi all This is my first post and I admit it is a little noobish, so please go gentle :) After extensive research particularly on this forum, coupled with the fact that I own numerous Netgear p...
mdgm-ntgr
Jun 21, 2012NETGEAR Employee Retired
rozel wrote:
1. How do I set a password on a particular share without it applying to the other shares I've created
You can't set a per share password. However you could create users. Each user will have a private home share. You can then use this trick to mount the shares: Using Multiple Credentials in Windows
rozel wrote:
2. By right-clicking c or d, in Windows explorer - it's properties doesn't show available disc size, it simply shows 0 bytes - is this correct?
Map a network drive and you should see how much space is available.
