DieselDriver
Dec 03, 2019Aspirant
ReadyNAS Duo v2 - no partitions
Hello, some weeks ago I had to replace one defective harddisk. Then after the sync (RAID 1) everything ran without problems. Some days ago the Netgear tool shows "damaged root directory" and doe...
- Dec 10, 2019
UFS Explorer 5.26 also worked fine to recover all the data.
Dec 03, 2019Guru - Experienced User
DieselDriver wrote:
So I tried to connect the harddisks to a computer but I cannot see any partitions on all the three (one defective, two working harddisks) harddisks.
You should see partitions in the Windows Disk Manager, but of course you can't mount them w/o linux tools.
How large are the disks? Some older USB/SATA adapters fail with disks > 2 TB.
What firmware are you running in the NAS? I'm asking because it's important to confirm the model (the labeling is confusing, and many v1 owners mistakenly think they have a v2).
A v1
- says ReadyNAS Duo on the front chassis
- runs 4.1.x firmware
- might say v2 on labels on the side or back.
A v2
- says ReadyNAS Duo v2 on the front chassis
- runs 5.3.x firmware.
