DieselDriver
Dec 03, 2019Aspirant
ReadyNAS Duo v2 - no partitions
Hello, some weeks ago I had to replace one defective harddisk. Then after the sync (RAID 1) everything ran without problems. Some days ago the Netgear tool shows "damaged root directory" and doe...
- Dec 10, 2019
UFS Explorer 5.26 also worked fine to recover all the data.
Dec 04, 2019Guru - Experienced User
DieselDriver wrote:
Which tool do you suggest me to mount one of the disks?
Try R-linux for Windows (which is free). https://www.r-studio.com/free-linux-recovery/
Note that in your ReadyNAS the mirrored disk isn't partitioned the same way as the main one, and you won't see a partition for the data volume on it. But you will on the main disk (which is usually disk 1).
I also suggest running vendor tools to test the disk in the PC - Lifeguard for Western Digital; Seatools for Seagate.
DieselDriver
Dec 04, 2019Aspirant
Thanks.
In meantime I tried the UFS Explorer Professional Recovery 7.14 and it's working for the disk 2.
On disk 1 I will try R-Studio 8.
- DieselDriverDec 10, 2019Aspirant
