machlo1
Mar 07, 2013Follower
ReadyNas Duo v2 - openVPN + iptables problem
Hello I have problem with openvpn configuration. At this moment configuration of openvpn is correct, i can connect with my nas using vpn but... (here is problem) :i cannot forward port using ipt...
chirpa
May 15, 2013Luminary
Many iptables modules are not included. If you want nat,conntrack,etc, you'll have to compile them from the GPL sources.
- Aug 22, 2020Retired_Member
