airwaves2020
Aug 30, 2026Aspirant
Readynas duo v2 and seagate ironwolf
Hi, replaced a failed drive in my readynas with this https://www.scan.co.uk/products/4tb-seagate-ironwolf-st4000vn006-nas-hard-drive-35-hdd-sata-iii-6gb-s-5400rpm-256mb-cache-cmr And the readyn...
Sandshark
Aug 31, 2026Sensei
First off, we need to know if you have a "real" V2. Unfortunately, Netgear made a branding blunder in releasing a product called a "V2" when they had already used "v2" to indicate a small change in the original Duo (which we refer to here as a "V1"). If your NAS says "ReadyNAS Duo V2" on the front, it's the "real" V2. If it simply says "Readynas Duo", it's a V1. That makes a difference because the V1 only supports drives up to 2TB where the V2 supports larger ones. Any other labeling is unimportant here.
Nonetheless, both should recognize the drive, the V1 will simply not properly recognize its size.
What specific status does the GUI show? Are there any messages in the log related to drive insertion or removal? Did you add the drive with power on or power off?
Did the original drive "disappear" completely or just give errors? If it disappeared, it may be that you have a NAS hardware issue, not a drive issue. Have you tested the old drive outside the NAS?
- airwaves2020Aug 31, 2026Aspirant
Thanks for you help, I have done some more testing and the drive works outside the enclosure, so it's the enclosure. Looking for a replacement now, all my files are backed up in the cloud, not going to lose anything
- StephenBSep 01, 2026Guru - Experienced User
Do you have the "real" v2? (ReadyNAS Duo v2 label on the front panel)?
Or do you have the original Duo (ReadyNAS Duo label on the front panel)?
