freddyfruitbat
Feb 10, 2015Guide
ReadyNAS Duo v2 won't reboot or do OS reinstall
My ReadyNAS has worked perfectly in its present configuration for many months, 24/7, with no issues at all. However, this week I have been unable to access my shares from my PC, and the ReadyNAS no...
vandermerwe
Feb 10, 2015Master
It seems if you get to the point where all the LEDs are lit then you have accessed the boot menu. You then press the backup button - are you sure you are pressing the correct button? Pressing it once should take you to the power led on, are you saying when you press it a second time then nothing is happening?
Do you have ssh enabled?
