freddyfruitbat
Feb 10, 2015Guide
ReadyNAS Duo v2 won't reboot or do OS reinstall
My ReadyNAS has worked perfectly in its present configuration for many months, 24/7, with no issues at all. However, this week I have been unable to access my shares from my PC, and the ReadyNAS no...
freddyfruitbat
Feb 10, 2015Guide
vandermerwe wrote: You then press the backup button - are you sure you are pressing the correct button? Pressing it once should take you to the power led on, are you saying when you press it a second time then nothing is happening?
Yes - that's what I was expecting to happen, but after pressing 'backup' once, nothing else happens.
Do you have ssh enabled?
I haven't a clue I'm afraid. Not something I'd know anything about myself; but conceivably it might have happened during some issues I had a couple of years ago
