jamsgra
Nov 07, 2011Follower
ReadyNAS Duo vs. BT Infinity Hub
Hi, I have just had BT Infinity installed, and I can no longer access my readyNAS box. The new set-up uses a different set-up to my previous Broadband provider, as the BT hub now sits behind a f...
sphardy1
Nov 07, 2011Apprentice
It would seem that you have set a static IP address on the Duo at some point.
You can reset the Duo network settings so that the IP address will be assigned by DHCP by performing a Firmware Reinstall (See FAQ for instructions). The Reset will not affect your data, but will reset your admin password to the default as explained in the FAQ
