jamsgra
Nov 07, 2011Follower
ReadyNAS Duo vs. BT Infinity Hub
Hi, I have just had BT Infinity installed, and I can no longer access my readyNAS box. The new set-up uses a different set-up to my previous Broadband provider, as the BT hub now sits behind a f...
andrewuk
Nov 08, 2011Aspirant
You could try setting your PC to a static IP address on the same subnet as the Duo, which should allow you to communicate with it.
i.e. change your PC to 192.168.0.x
connect to the duo and set it back to dhcp
change your pc back to dhcp
log back into the duo (raidar will tell you it's new dhcp assigned IP) and set a new static IP in the range of your new router (e.g. 192.168.1.2)
