CLB10
Nov 18, 2017Follower
ReadyNAS Duo
Would really appreciate any help on this situation. The Model No on the device shows Duo RND2120 v2 but that No is not recognised by Netgear. The RND 2120 is shown on a label stuck on to the plat...
Sandshark
Nov 18, 2017Sensei
Netgear used "V2" in two different ways, which is a recurring problem in people properly identifying their NAS. More than half the Duo's currently listed on eBay as a "Duo V2" are what is now called a V1. If the part number ends in -100NAS, and from the description of your unit, yours probably does, it is a V1 in the language currently used. The unit currently referred to as a "V2" is a completely new design with different firmware, not a minor board change like the original "V2".
RAIDar 4.3.8, available at ReadyNAS-Downloads works fine in Windows 10 and should find your NAS as long as it is functional. If it doesn't, come on back and we'll see if we can help get it up and running again.
