PhilB-SC
Oct 25, 2016Aspirant
ReadyNAS Firmware Update Destroyed Volume
Greetings. I recently purchased 2 ReadyNAS 312s. During setup, I was required to set up the drives with encryption due to them being used by the HR department. I was having an issue where I cou...
- Oct 25, 2016
Hello PhilB-SC,
You might really need to reinstall and start from the scratch since there is still no files stored. However, did you already reboot with the USB stick that has the key for encrypted volume?
Welcome to the community!
JennC
Oct 25, 2016NETGEAR Employee Retired
Hello PhilB-SC,
- PhilB-SCOct 26, 2016Aspirant
Ahhhh.... I should of thought to put the USB key back in. I have them removed for security. That makes sense.
I did have the admin password changed. I created another account though to access the files.
Thank you both for your replies.
- JennCOct 26, 2016NETGEAR Employee Retired
Hello PhilB-SC,
Thank you for informing us what caused the problem and solved it.
Please continue posting any suggestions, comments or questions, we value your contribution to the community.
