DavidCXX
Feb 19, 2016Aspirant
Readynas freezes on start up after constantly crashing
Finding this extremely frustrating. After various problems last year that appeared to be fixed by a OS reinstall, my NAS has been crashing more and more frequently over the last couple of days. I hav...
DavidCXX
I can occasionally get it to boot menu and so that it says OS reinstall but then the NAS won't actually start the reinstall when I press the power button. If I press the reset again it boots and I'm back to it crashing. I am not at all technical but this system isnt great surely...?!
- StephenBFeb 19, 2016Guru - Experienced User
What firmware are you running? Have you disabled the antivirus service?
- DavidCXXFeb 19, 2016Aspirant
I'm not sure what firmware it is as I can't get it working long enough to check - I updated it at the end of last year. And sorry, I was trying the USB recovery tool rather than OS reinstall, my mistake, either way it just goes back to freezing whilst booting.
ok Ive tried using another USB and that seems to have worked - my antivirus is on but Im being alerted to a huge amount of threats - 40 and rising - help!
