whathappenednas
Jun 27, 2018Aspirant
ReadyNAS has failed and need assistance recovering iSCSI LUN
Hello,
If I've posted this in the incorrect location, please let me know where I should repost.
I've got a RNDU2000 with 2 x 2TB HDD's in RAID 1. On this drive, there was an iSCSI LUN which w...
whathappenednas
Jun 29, 2018Aspirant
If I were to purchase a Netgear, would it then be an option?
Jun 29, 2018Guru - Experienced User
Yes. You could purchase a used NAS that runs 4.2.x firmware (ultra/pro), and try migrating the disks,
It is also possible to temporarily mount the volume as read-only in an x86 OS-6 NAS (RN300 or better): https://kb.netgear.com/29957/ReadyNAS-Migrating-disks-from-RAIDiator-4-2-to-ReadyNAS-OS-6-x86
You could try installing R-linux for Windows on the PC, and see if that can access it. https://www.r-studio.com/free-linux-recovery/
- whathappenednasJun 29, 2018Aspirant
Hi StephenB,
Thanks for your response.
I've already purchased r-studio and was able to recover the .iscsi folder. The file inside (guessing LUN) was 1.3TB which I labelled name.iso but when I tried to mount it, received an error message about potential corruption. There were also some other folders which I forgot about that had some files I've recovered successfully without receiving the error which leads me to believe that the error I received when trying to mount the LUN was because it's not how it's done (or some other legitimate reason) and not that the file is actually damaged. Perhaps Windows couldnt read it.
With regards to purchasing a new NAS, happy to do it but would the migration you're suggesting simply be slotting the good disk in to the new NAS or is there more of a process to it?
WIth the new NAS, would you recommend any of the following?
Netgear RN21200-100AJS
Netgear RN204-100AJS
Netgear ReadyNAS RN42200-100AJS
Thanks again
- StephenBJun 30, 2018Guru - Experienced User
Did you try not renaming the LUN, and accessing it with the windows iscsi initiator?
- whathappenednasJun 30, 2018Aspirant
TBH I read the extension thing somewhere else and didnt think to try what you've suggested. Would that simply be a matter having the iscsi file available on the computer and adding 127.0.0.1 as the target? I don't have access to the computer at the moment as it's offline so will have to give this a try on Monday.
With regards to purchasing a new NAS, would you recommend any of the NAS models in my previous post?
Thanks StephenB
I believe so, yes.
If you want to migrate the disks, you'd need the RN422 or an RN420 series with more bays). The RN2xx series are ARM-based - they work well, but don't support disk migration from your ultra.
