mark3
Feb 02, 2016Aspirant
ReadyNAS is showing up as having two ip addresses on my home network
Hi, I was wondering if someone could help me. I have a ReadyNAS that is working correctly on my home network. It has an IP address of 192.168.1.2, all my other devices on the network start 192.16...
- Feb 02, 2016
The 172.31.51.213 address won't work on your 192.168.x.x network, and (like 192.68.1.2) is a private (not internet routable) address.
Port 554 (and sometimes 7070) are used for media streaming, but there also are a lot of reports of false alarms reported by various port scanners for those two ports.
What ReadyNAS model and firmware?
If you have two ethernet ports are both connected?
Did you try disabling the openvpn service and rebooting the NAS?
BrianL2
Feb 02, 2016NETGEAR Employee Retired
Hi mark3,
Welcome to the community!
I don't remember the OpenVPN add-on or server use these ports that you mentioned. Are you using the ReadyNAS as a media server for your Apple devices or through iTunes?
Kind regards,
BrianL
NETGEAR Community Team
- StephenBFeb 02, 2016Guru - Experienced User
- mark3Feb 05, 2016Aspirant
Hi Brain and Stephen,
Thanks very much for your advice. I had previously disabled the VPN but it was still appearing, however I did not think to restart the readyNas.
Alas, after disabling the VPN Server I restarted and it has now disappeared. Thanks for your help.
Mark
