ilkevinli
May 27, 2011Aspirant
ReadyNAS keeps disppearing from Tivo
Hi, I have 2 Tivo Premieres in my house and for some reason, my ReadyNAS Ultra 4 Plus keeps disappering from them. I have to login to the ReadyNAS and hit the Rescan Media Files button and then i...
alexofindy
May 29, 2011Aspirant
The same problem just started happening to me. I have a Tivo Premiere XL, and a Readynas Ultra 6 Plus, running 4.2.17 firmware.
Used to work well.
Now, all of a sudden the entry for my Readynas drops off the Tivo's "My Shows" screen. I also seem to have trouble with the archiving function (the copying of tivo shows with the "Keep until I delete" flag set to my Readynas).
I updated the ReadyDLNA service on my Readynas to version 10.0.19.3, using the add-in download on the Readynas web site. This did not help.
If I restart the ReadyDLNA service on my Readynas, the problem is fixed, but only temporarily.
The problem developed during the past week or so, during which time my Tivo updated its own firmware to version 14.8. There's a good chance this caused the problem. Can the other posters indicate if they just had a Tivo firmware update at the time the problem began? (As a note to folks reading this who are not familiar with Tivo's: Tivo's must be connected to the Internet to function, and firmware updates are controlled by Tivo's central servers. The end user has no control over when the Tivo updates its firmware, and the end user cannot go back to an earlier version of the firmware)
Thanks!
Used to work well.
Thanks!
