ilkevinli
May 27, 2011Aspirant
ReadyNAS keeps disppearing from Tivo
Hi, I have 2 Tivo Premieres in my house and for some reason, my ReadyNAS Ultra 4 Plus keeps disappering from them. I have to login to the ReadyNAS and hit the Rescan Media Files button and then i...
mrrulke
Mar 07, 2013Aspirant
just did the install while tailing the log file.
here is what i got not sure if it is bad or good just though you might want to see.
[2013/03/08 12:05:20] minidlna.c:1069: warn: Starting ReadyDLNA version 1.1.0-rc 4.
[2013/03/08 12:05:20] sql.c:88: error: prepare failed: no such column: VALUE
SELECT VALUE from SETTINGS where KEY = 'UPDATE_ID'
[2013/03/08 12:05:20] minidlna.c:390: warn: Database version mismatch; need to r ecreate...
[2013/03/08 12:05:23] minidlna.c:1107: warn: HTTP listening on port 8200
[2013/03/08 12:05:23] scanner.c:690: warn: Scanning /c/media
[2013/03/08 12:05:15] minidlna.c:153: warn: received signal 15, good-bye
im at work now so i cant really check it out if it is working at serving files. i will post back an update
