devfaulter
Oct 03, 2016Aspirant
ReadyNAS Management services offline (6.5.2)
Hello I am experiencing very similar problems to that described in the topic: "ReadyNAS Management services offline after 6.5.0 update". I was unable to try the fix as it seemed to be communicat...
- Oct 03, 2016
Somehow the DLNA config file on your system had some binary characters appended to the end, which confused the config parser. I've fixed it up manually on your system, and this situation will also be handled gracefully in future firmware releases after 6.6.0.
mdgm-ntgr
Oct 03, 2016NETGEAR Employee Retired
Please send in the logs zip you downloaded using RAIDar (see the Sending Logs link in my sig).
devfaulter
Thanks for your quick reply. Logs now sent.
- mdgm-ntgrOct 03, 2016NETGEAR Employee Retired
Looks like you updated directly from 6.3.2 to 6.5.2
It appears you had some apps installed. Which ones?
- devfaulterOct 03, 2016Aspirant
The only app that I installed was OwnCloud, that had been running for some days without any issues prior to the problem I described that started yesterday evening.
- SkywalkerOct 03, 2016NETGEAR Expert
Sent you a PM for remote access.
- Jun 10, 2022Retired_Member
