colmosiris
Aug 03, 2015Aspirant
ReadyNAS model RND4000-100EUS - replacement power supply
Hi there! I have a ReadyNAS box that needs a new power supply. The box and cable that connects the NAS to the wall socket that is, not the internal power unit. I've found some on ebay, but they m...
- Aug 03, 2015
All you need is the correct cable, there is no transformer. The input voltage to the supply can be 100-240.
For instance this: http://www.amazon.co.uk/Mains-Cable-Power-Monitor-Kettle/dp/B003P49P1I
colmosiris
Aha, now I see the confusion! No, I'm not talking about the internal unit, I'm talking about the cable and possible transformer that connects the NAS box to the wall plug socket. It will have a 3-pin kettle lead plug on one end, and a 3-pin 240 volt plug on the other end. Whether there's a transformer in the middle somewhere, I just can't remember.
My other ReadyNAS box has a 4-pin plug, that connects via a transformer, to the wall plug socket. The socket on this one is different.
Or can I assume that as the box I'm asking about has a 3-pin kettle socket, any old kettle lead will do, and it doesn't need a transformer, like my other NAS box does? I really can't remember what it had now.
This is what the plug that fits the power socket on the back of the ReadyNAS box looks like:
<http://laptopsockets.co.uk/index.php?main_page=popup_image&pID=530>
Aug 03, 2015Guru - Experienced User
- colmosirisAug 03, 2015Aspirant
Oh, that's brilliant! That's why I couldn't find it, I was looking for something else! I've got loads of these leads! Problem solved, yay!
Thanks so much :)
