olizan74
Dec 05, 2016Aspirant
Readynas not showing in Network neightbour
Hello, i have some troubles with my readynas duo RD2000. Radiator 4.1.15 [1.00a043] My windows 10 pc's doesn't see the nas in the windows network neightbour. How could i resolved this issue ? ...
Dec 05, 2016Guru - Experienced User
The only issue is the network neighborhood? You can access the shares and the files in them from the Win10 PCs?
There isn't an easy fix for the network neighborhood (and it can come and go).
But there are a couple of workarounds - on is to add shares as "network locations" in file explorer. You can also put a shortcut to the NAS on the desktop.
olizan74
yes, it's the only issue.
I can access via ip, network name, create shortcut, share etc..
But, even if i access to the nas, the network neightbour doesn't see it.
- olizan74Dec 05, 2016Aspirant
i have just make a test. I have install windows 7 in a Vmware et it works. 7 see the nas trhough the Network neighbour
- StephenBDec 05, 2016Guru - Experienced User
Understood.
I've never seen a good fix posted (and this is a common Windows issue, not unique to ReadyNAS). So I use the workarounds (mapped drives, added network locations, desktop shortcuts).
