SJMarty
May 20, 2017Aspirant
ReadyNAS NV - Fan 1 has failed
Hello, I have an old ReadyNAS NV that has been loyal for years. I replaced the power supply under the recall a number of years back and other than that, it's never given me any trouble. The dri...
Sandshark
May 20, 2017Sensei - Experienced User
I think it's unlikely that a power supply problem would cause a fan problem and nothing else. But since you have the supply on hand, what do you have to lose trying it?
SJMarty
May 23, 2017Aspirant
I swapped the power supply out on Saturday afternoon. It went three days but now the "fan 1 has failed" came back. Any other suggestions?
- SandsharkMay 23, 2017Sensei - Experienced User
Without a schematic (which Netgear has not released), anything else would be a poke in the dark.
- SJMartyMay 23, 2017Aspirant
Worth pulling the board out and looking for something obvious? Cold solder joint? I'm grasping...
Thats a pretty safe poke in the dark. Unlikely to find something, I think; but why not? The fan connection is on the SATA backplane, if I recall correctly, so disconnecting that and re-connecting could be all it needs (another long shot).
