_ommunist
Jan 04, 2012Aspirant
ReadyNAS NV+ and Lion problem with mDNS and avahi
This is from daemon.log. I first experienced problems with machine that was updated from Snow Leopard, but now it seems the fresh Lion installation also pulls ReadyNAS NV+ (sparc) out of network exist...
_ommunist
Feb 07, 2012Aspirant
chirpa wrote: Do you have Jumbo frame devices on the network? The system is receiving packets larger than the RX buffer, causing a buffer overrun. If you have Jumbo frame devices in use, can you try enabling Jumbo frames on the NAS itself (FV>Network>Interfaces)?
What switch/hub do you have the NAS connected to? I see you have speed/duplex forced to 100/Full Duplex. Why not using Auto, to get 1000?
Also, for what purpose was the MTU set to 1430? Do you have Vista/7 Wireless devices, and tried using the workaround posted by a few forum users?
I'll check for devices that can possibly send Jumbo frames.
Its a gigabit switch/router.
Yes, I tried that. Win7 workstation which had the only option to be connected wirelessly had problems and setting MTU solved that.
Also - can buffer overrun be caused by a printer sending MTU larger than 1430?
