BertDude
Feb 19, 2017Aspirant
ReadyNas NV+ bootup issue
Hi, let me introduce myself to the community, i am Bert. Though i am new to the community, i have been using the ReadyNAS devices from the original creator. i own three 600's and two NV+'s. So on to...
Sandshark
Feb 19, 2017Sensei
Power itt on and hold the button for about 5 sseconds. You should see "skip volume check" on the display. If this boots you successfully, update your backup immediately, then look for a reason the volume check hung.
BertDude
Thanks for your quick response, i did what you said however its now stuck on the booting process.
