nogden
May 20, 2011Follower
READYNAS NV endless reboot - new PSU - Reset no luck.
Readynas NV - in service since 2007-ish original power supply (now a new PSU). Running 4.1.7 I updated to 4.1.7 around Apr 23, from probably 4.0-something. I did not have any issues at that tim...
stanger89
Aug 25, 2011Aspirant
I'm having a very similar problem with my X6. Although for me, judging by the lights, it's rebooting about every 17 seconds. Besides that though it behaves exactly as you predict, it comes on automatically when I plug it in (or hit the switch on the back), if I hold the power switch down, after turning it on, it will go through the power menu (TFTP boot, memory test, etc).
I'd be interested to know what capacitor to try (or anything else) or better yet the software fix. Though I don't have a spare X6 to put the disks in, I have "successfully" mounted the disks in a linux machine. Though I'm not sure how to mount the "system" volume to change the startup scripts or pull logs.
Any help would be appreciated.
