AndrewB11
Dec 11, 2014Aspirant
ReadyNAS NV Failing to start
ReadyNAS NV (c.2006) was working fine yesterday. 4 disks installed. When attempting to access it today, I am unable to do so. RAIDar can't see it, doesn't respond to ping. Pressing and holding the...
vandermerwe
Dec 11, 2014Master
Do you have a backup?
If you have the logs, look in disk usage log and post what's there.
Had you received any messages about disk errors. You must exclude a disk problem by testing each disk with vendor tools, use the long or extended tests. Remember to label the disks so you know which slot they came from, and replace all disks before powering on again.
You could run a memory test using the boot menu.
http://kb.netgear.com/app/answers/detai ... U5bQ%3D%3D
