AndrewB11
Dec 11, 2014Aspirant
ReadyNAS NV Failing to start
ReadyNAS NV (c.2006) was working fine yesterday. 4 disks installed. When attempting to access it today, I am unable to do so. RAIDar can't see it, doesn't respond to ping. Pressing and holding the...
Dec 13, 2014Guru - Experienced User
You can boot the system with any three disks (and it will boot w/o disk 1).
So the next step is to try the #2 + #3 + #4 boot.
Then back up your data to another device - particularly important because you know disk 4 also has bad sectors.
