EquinoxBlue
Oct 13, 2019Aspirant
ReadyNas NV+ Freezing Dead Drive?
I've had a ReadyNAS NV+ for a very long time and it has served me well. Lately it seems to freeze after running for about an hour and is unusable. All I can do is pull the power plug.
For the bri...
EquinoxBlue
Oct 15, 2019Aspirant
Thank you very much for your detailed reply.
I bought a new drive to replace drive 2, but after I've installed it now the NAS won't power on at all. The power button does nothing. I think maybe it's finally just died.
I might make an attempt to put the drives in a PC and see if I can access the array, but I think I might have to accept the fact the data is gone.
Oct 15, 2019Guru - Experienced User
EquinoxBlue wrote:I might make an attempt to put the drives in a PC and see if I can access the array, but I think I might have to accept the fact the data is gone.
If you do put them into a PC, you'll need RAID recovery software that can handle the ext file system. R-Studio is one option. https://www.r-studio.com/
Does it power up with all disks removed? Label them by slot as you remove them.
- Jan 17, 2024Retired_Member
