pruttlars
Dec 26, 2015Aspirant
ReadyNas NV+ Frontview page - blank buttons - help!
Hello! Model: ReadyNas RND4000 v3 Firmware: 4.1.14 4 x 2TB disks A while ago, I was unable to access my NAS directly or via the network and then I did a reinstallation of the OS follo...
- Jan 08, 2016
pruttlars wrote:
No, I am not comfortable with linux command lines. And regarding the other question, I am not sure if I have ssh enabled as I am unsure what ssh is.
ssh is a way to connect to the NAS that lets you enter linux command lines. It sounds like this approach isn't the right one for you - much too risky.
pruttlars wrote:
So that leaves me with your other ways to proceed then. If I back up the data, I guess I just press the "back-up button" on the unit, right?! Where will the back-up be stored? On the NAS? I'm not sure I ever made a back-up before. Don't think so.
Unfortunately that backup button is configured using the web ui that doesn't work (and since the ui doesn't work, we can't really predict what pressing the button will do).
The safest way is to get some USB disk drives, connect them to your PC and copy data to those drives from the NAS. If you are using a PC, you can use a free utility like teracopy which can verify the copy.
The speed depends on your network, but it will take a while. If you have a wired gigabit connection on the PC and the NAS it will take perhaps 16 hours per TB you need to copy. Your drives probably aren't completely full, but still it is several days. BTW, though this is slow, connecting the USB drive to the NAS would be even slower.
Using per-incident support is likely faster.
pruttlars wrote:
Final question; is there any risk for my files and system if I just leave it as it is, and put aside the opportunity to reach the unit via frontview?
A very important question. If the OS partition is nearly full, then there is a risk that that the NAS will completely freeze, and you will lose all access to your files.
Support can still log in remotely and fix it. But the full partition idea is a theory - it is not confirmed and there are other things that could be wrong.
My advice: start backing data as quickly as you can (starting with personal stuff you can't replace), and perhaps in parallel start a per-incident support case.
pruttlars
Jan 08, 2016Aspirant
Thanks for your prompt reply.
And after that, how do I proceed making a factory reset and rebuild the NAS and restore the data? I have a feeling the beforementioned procedure is quite time consuming, right?! Approxiomately how long do you think it'll take? My NAS has 4 HDD's with 2 TB each. I guess filled around 6 TB with data.
Sorry for the hordes of questions. :)
Jan 08, 2016Guru - Experienced User
- pruttlarsJan 09, 2016Aspirant
Hi!
Thank you for your detailed answers.
I'll go with your recommendation and buy a couple of big USB disk drives, connect them to my PC and copy data to those drives from the NAS, like you suggested. And then do a clean re-install of the whole system and finally transfer back all of the files to the NAS again. A pretty time consuming process I am sure, but reading your expert advices leaves me with no other choice as I see it.
Also, thanks for the tip with Teracopy. Downloaded it, tried it and it works like a charm. I'm sure this program is going to help making the file transfer process much easier.
You guys really know your things and I am truly greatful for all of your help.
Thanks again!
- BrianL2Jan 09, 2016NETGEAR Employee Retired
Hi pruttlars,
Just update this thread on what happens next. For the time being, you may tag this thread as resolved by clicking the "Accept as Solution" button in one of the responses that you received.
Kind regards,
BrianL
NETGEAR Community Team
