arjunrc
Aug 07, 2014Aspirant
Readynas NV+: messed up after apt-upgrade
Hi all, I have a readynas NV+ (sparc). I had SSH enabled and did the horrible mistake of doing apt-get upgrade --- boom, the system got messed up. I am only able to SSH in now via the default r...
mdgm-ntgr
Aug 07, 2014NETGEAR Employee Retired
You should still backup your data if you can access it and do a factory reset (wipes all data, settings, everything), then restore your data from backup.
We don't support doing an apt-get upgrade and your system may be unstable.
