Bigrbob's avatar
Bigrbob
R7800 Firmware V1.0.2.92 update messed up readyshare
Nighthawk R7800 Firmware V1.0.2.92 update messed up readyshare. After the reboot the drives show up on the readyshare web screen, but does not show up on filemanagers on my LAN. Linux Mint (2 different versions). Reset the Router again, still no joy.
Thanks in advance
Bob
  • I rolled it back to 1.0.2.90, now readyshare works as before.
    Thanks
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi @Bigrbob, may we know if rolling back the firmware fixes the issue for you?
    Dexter
    NETGEAR Team
    • Bigrbob's avatar
      Bigrbob
      Thanks
      • michaelkenward's avatar
        michaelkenward
        Still working here on R7800-V1.0.2.92
  • I dont understand how rolling back is an accepted solution?
    Please keep this issue open so that we can get some answers from Netgear.
      michaelkenward
      Not much point in that.
      You should know that this community is essentially a user-to-user venue to talk about technical issues, with some input from a small band of Netgear techies.
      As you didn't start this conversation, if you want more help you might do better to start a new conversation.
      As already explained, you do not need to roll back to older firmware to use ReadySHARE. It works just fine for me with the newest firmware. So it is possibly a problem at the user end.
      • wifi_problems's avatar
        wifi_problems
        Tutor
        Would you share steps you used to mount drive in windows/linux?
        For me and OP, the old ways of mounting didnt work as soon as upgraded to .92 but downgrading back to .90 worked as before. So clearly there is something wrong with the update.
        Thanks.
