arjunrc
Aug 07, 2014Aspirant
Readynas NV+: messed up after apt-upgrade
Hi all, I have a readynas NV+ (sparc). I had SSH enabled and did the horrible mistake of doing apt-get upgrade --- boom, the system got messed up. I am only able to SSH in now via the default r...
arjunrc
Aug 08, 2014Aspirant
mdgm wrote: You should still backup your data if you can access it and do a factory reset (wipes all data, settings, everything), then restore your data from backup.
We don't support doing an apt-get upgrade and your system may be unstable.
Thanks mdgm, agreed.
Would you know if I can download a readynas version (NV+ Sparc) that has kernel support for iptables? I use it as my openVPN server and I need iptables for some routing issues I am facing. Just installing iptables does not work as the current kernel does not support it
Firmware: RAIDiator 4.1.10 [1.00a043]
readyNAS:~# cat /proc/version
Linux version 2.6.17.14ReadyNAS (root@calzone) (gcc version 3.3.5 (Infrant 3.3.5-1)) #1 Wed Jun 20 20:08:20 PDT 2012
