arjunrc
Aug 07, 2014Aspirant
Readynas NV+: messed up after apt-upgrade
Hi all, I have a readynas NV+ (sparc). I had SSH enabled and did the horrible mistake of doing apt-get upgrade --- boom, the system got messed up. I am only able to SSH in now via the default r...
mdgm-ntgr
Aug 08, 2014NETGEAR Employee Retired
There is newer firmware for your NAS than what you are running.
Sparc is long EOL (End-Of-Life).
You would likely have more success with newer hardware, however it's not something we would support.
